Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oil pressure
Kirk West
04-09-2013 06:44:39
Yes, I"ve got blue smoke out the oil breather too. I suspect I may have some stuck piston rings since this tractor sat more than ran. Also has ran cold for who know how long. Will check out the relief valve as soon as this blizzard blows by.
04-09-2013 09:41:07
 Re: Oil pressure in reply to Kirk West, 04-09-2013 06:44:39
Stuck/worn rings or liners would be indicative of that. Oil can be sucked into the cylinder on the intake stroke due to the vacuum induced by the piston traveling down the bore. Thus the blue smoke from exhaust.
Combustion products will be forced past the rings on the power stroke, thus the smoke from oil filler neck.
An ATF soak could help some by pouring a teaspoon down the spark plug hole and letting it set to free up stuck rings.
You can have all the snow you want...sunny and 72 here in Glendale, KY
Good Luck
