TractorLinks.com
Show Parts for Model:
Re: Oil pressure
JCinKY
04-09-2013 05:37:39
The pressure relief spring and plunger is behind the big 15/16" nut on the very front of your 2N engine. It will be right beside the #3 plug nipple on your front mount distributor under the upper radiator hose. Just remove the nut and all three (nut, spring, plunger) will come right out; careful there is a little spring tension. The flat spot on the plunger is supposed to be there.
Blue smoke from the exhaust is rings/valve seals. Blow by would be smoke from the oil filler neck.
