TractorLinks.com
Show Parts for Model:
Re: Oil pressure
Kirk West
04-09-2013 05:29:43
I"ve got a 2N that"s reading 50+ oil pressure. Already changed the oil and filter. Where is this pressure relief valve? Getting blue smoke so if pressure is too high, excessive blow by?
TheOldHokie
04-09-2013 06:34:00
 Re: Oil pressure in reply to Kirk West, 04-09-2013 05:29:43
No - higher oil pressure does not produce blow-by.
TOH
JCinKY
04-09-2013 05:37:39
The pressure relief spring and plunger is behind the big 15/16" nut on the very front of your 2N engine. It will be right beside the #3 plug nipple on your front mount distributor under the upper radiator hose. Just remove the nut and all three (nut, spring, plunger) will come right out; careful there is a little spring tension. The flat spot on the plunger is supposed to be there.
Blue smoke from the exhaust is rings/valve seals. Blow by would be smoke from the oil filler neck.
