SPARK PLUG WIRES
Recevied new plug wires that are the oem type for my
frt dist 8N,the question I have.they are color code
#1 and #4 are obvious but 2&3 are the same lth.
Does any one have the correct color code for the
spark plug wires.Ive been looking but could not find
it. Thanks George
George........never heard of color coded sparkie wires. I have seen tinted clear insulation on display hot-rods. They ain't worth 'chit!!! The sparkies jump right thru the insulation and dance the nite away.
The original 9N sparkie wires were covered with a "braid" that could have been color coded as the rubber insulation for sparkie wires was NOT very good. Unless yer a sphincterly challenged originality inspector, I would NOT waste my $$$ on color coded wire.
The important thing, whether color coded ...or... black or yellow, is the center conductor is stranded copper wire and NOT modern resistive string. .......Dell, yer self-appointed sparkie-meister
Get some colored vinyl tape and code your wires.Early braided wires for Ford V8s had a colored thread to id them after they were pulled into the conduits.
The wires I have are the OEM type that are color coded,these are the correct type that came with the tractor back in the day,they have the colored thread through them,each wire has A diff color.I"am making the tractor as correct as possible,the same as when my father bought it in 1949,my 2 other 88N will be work tractors this one will be my trailer queen.the other 2 have std type stuff on them and run fine, Thanks for the response George
Dell, Here are some color coded sparkie wires. Dennis Carpenter sells them. Supposed to be like original.
Thanks guys for the input and H Cooke for the picture those are the ones that I have from Brilliam,I will use that photo to put my wires on.When I get the red and wheels on I will try to post A picture Fellow Ner George
