Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need advice re ring/crank bearing replacement
Ken(Ark)
04-07-2013 19:01:07
A lot has to do with time , money , and how much you need a tractor .
If your time is free and you enjoy doing your own mechanic work then you can refresh the motor with some rings and bearings .
A used N is not really the tractor you want if you are paying some one else to rebuild the motor , etc .
To bring the pressure up I would spend a few bucks getting the oil pump rebuilt . These oil pumps sit above the oil line and have to suck oil up before it builds pressure . Worn pumps can easily lose prime which causes the motor to run dry on start up .
You wont really know about reringing until you get it apart . The thin steel sleeves can end up in the oil pan when they are excessively worn , the cast thick sleeves stay intact .
Again money has a lot to do with it , fresh bearings will take out a lot of slack . For about $125 - $150 you can get it in fair shape . If you are reringing a used cylinder , I would not use the chrome rings since they are harder to get to seat in . A plain steel ring won't last as long , but since the cylinder is already worn there is no real loss .
Before you take out the valves , see if they will hold a spoon full of gasoline from leaking past . If they will then lap them and go .
