I just got a NAA, 6 volt positive ground.
It had starting issues and needed to be shorted across the solenoid to start, the starter switch was bypassed.
I replaced the wiring, the solenoid, starter switch and key switch. The starter switch will not work, but has continuity when pressed.
Ironically, the new solenoid has a button on it that when pressed will crank the motor. I"ve never seen a solenoid like this.
Everything is wired correctly, the starter switch will not work.
What am I missing?
What am I missing?
