Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need advice re ring/crank bearing replacement
TheOldHokie
04-07-2013 14:59:28
No. You are talking two different issues:
1) You have low compression - that is rings/pistons/valves and/ory a valve job.
2) You have low oil pressure which indicates excessive bearing and/or oil pump clearances.
If you need rings (and that seems likely) a complete kit with new rings, pistons, and sleeves is my recommendation. Do the valves while you are there.
If you need bearings (seems likely) you likely need rods and mains and a regrind on the crankshaft. And rebuild the oil pump while you are in there.
At that point it becomes a complete overhaul.
JMO,
TOH
