Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need advice re ring/crank bearing replacement
L.B,
04-07-2013 12:09:30
What is you start up pressure? What is your warmed up pressure? Working pressure? Is your gauge working correctly as far as you know? You can have a idle pressure as low as 7 some say even 5 and be normal. 7 is the pressure that a lot of car idiot lights up the oil light. What is your oil weight? On your compression it may be stuck rings. Are you at 80 on all 4 cyls? Have you done a wet compression check with at least 6 power strokes. Do you get an excess of blow-by at the oil filler tube?
Mister B
04-07-2013 12:29:12
 Re: Need advice re ring/crank bearing replacement in reply to L.B,, 04-07-2013 12:09:30
All smart questions! I would say warm idle pressure is around 5-7 psi. Start up pressure is around 10-12. Same with engine revving. I had assumed that was very low. Have a new guage. Put in 15-40 weight per advice on this forum. Added a quart of Lucas. I am 80 on all cylinders, so I did not do a wet test as they seem evenly worn.
I had not thought of the blow by idea -smart- is there a way to measure that, either with instrument or ?
Dell (WA)
04-07-2013 15:12:48
 Re: Need advice re ring/crank bearing replacement in reply to Mister B, 04-07-2013 12:29:12
Mr B........the reason you do a "wet" test is to determine the amount of "wear" yer rings have. Ford specs: 90psi min DRY. It is not uncommon for un-used rings to stick inside the piston lands. ATF is recommended to "un-stick" stuck rings. Just 1-oz (thimble full) down each sparkie hole and letter set fer a week. All the ATF will drain down into 6-qts of engine oil and does not harm the engine oil.
You do know the N-Engine was designed fer 30-wt detergent oil, don't you??? 15-40wt oil is really just 15wt oil with heat sensitive additives that make it act like 40wt oil. CHANGE yer engine oil to 30wt detergent and watch yer oil pressure climb.
How do you detect "blow-by"??? Oil fumes out yer oil fill'em-up cap. ........Sheesh; respectfully the amazed Dell
TheOldHokie
04-07-2013 15:39:17
 Re: Need advice re ring/crank bearing replacement in reply to Dell (WA), 04-07-2013 15:12:48
Dell (WA) said: (quoted from post at 18:12:48 04/07/13)
Utter nonsense. If there is any observable change (doubtful) you will see a small drop in hot oil pressure with a grade 30 oil. Additives or not SAE 15W40 has a higher viscosity than straight SAE 30 when hot, And that is what affects hot oil pressure - PERIOD!!!!
TOH
This post was edited by TheOldHokie at 16:10:16 04/07/13 3 times.
Bulldozer
04-09-2013 09:46:16
 Re: Need advice re ring/crank bearing replacement in reply to TheOldHokie, 04-07-2013 15:39:17
Multi weight engine oil has viscosity index improvers that reduce the thinning with increase in operating temperature.
An SAE 10-30 wt oil is base 10 wt with viscosity index (VI) improver (heat sensitive additives)
The VI improver additives are susceptable to shearing damage in non synthetic oil. The damage can occur very early in the life of the oil, reducing the effective weight of the oil from 10W-30 to 10W-20.
Ever notice that when the oil is changed when using non synthetic multiple weight oil, the oil pressure gauge shows an increase in pressure? After the oil is used for a while, the oil pressure gauge shows a reduction in the oil pressure because the VI improvers have been damaged by internal engine shearing action.
Using synthetic muti weight oil the shear damage issue is basically eliminated.
Still, Prefer using straight SAE 30 non synthetic and change it once a year in my N whether it is used or not.
TheOldHokie
04-09-2013 10:54:32
 Re: Need advice re ring/crank bearing replacement in reply to Bulldozer, 04-09-2013 09:46:16
Bulldozer said: (quoted from post at 12:46:16 04/09/13) Multi weight engine oil has viscosity index improvers that reduce the thinning with increase in operating temperature.
All oil shears down. I don't know where you get your empirical data but I prefer laboratory analysis to anecdotal observation. Excessive shear loss on a quality conventional multi-grade oil is darn near non-existent. A used oil analysis is a good way to see this and there are many consumer testing services that will provide you with one. Just send them a small used oil sample and for ~$20 they will give you an analysis similar to this one. This UOA is a typical result showing the performance of a modern semi-synthetic/conventional 5W30 and as you can see the oil is still well withing viscosity grade after 5K miles and could probably go another 5K if you wanted to push it. The typical failure mode of a modern oil is over-thickening due to oxidation not viscosity shear down There are hundreds of similar UOA's available for viewing on the BobIsTheOilGuy website and you will find this level of perfortmance is typical of conventional oils with synthetics doing much better.
Conventional SAE 10W30 can (and occasionally is) formulated using a very high viscosity index (VHVI) conventional base oil and no viscosity modifiers whatsoever. SAE 10W30 synthetics are commonly formulated without viscosity modifiers. So this idea that the W grade is the "real" viscosity is factually inaccurate and only serves to confuse/scare people. Buy a good oil and change it on a normal interval and you won't have a problem with shear down.
TOH
PS> I added a second UOA for a conventional SAE 5W30 - still going strong but just barely out of grade after 9.2K miles - nearly double the recommended OCI for a conventional oil. Note the lab says he could stretch the OCI to 11K ....
This post was edited by TheOldHokie at 11:59:06 04/09/13 3 times.
Bulldozer
04-12-2013 19:46:30
 Re: Need advice re ring/crank bearing replacement in reply to TheOldHokie, 04-09-2013 10:54:32
Another consideration on this crankshaft bearing replacment question is at what point are the crankshaft journals ground and polished to another underside bearinfg size.
My thought is leave the journals alone unless the bearings are being eaten up and throwing lots of metal into the oil.
It is easy to replace the main bearings and rod bearing on this engine while the engine is bolted up to the transmission and front end.
Bearings are cheap compared to a rebuildable crankshaft, which are becoming more difficult to locate.
So if the oil pressure < 15 psig at 1500 rpm at normal operating temperature, then change out the bearings. Grind journals only if there is noticable bearing metal material mixed in the oil. This will help preserve the N tractor for generations to come.
Bulldozer
04-08-2013 07:19:21
Always thought that the engine needs minimum 10 psi oil pressure for every 1000 rpm.
So a 2000 rpm rated flat head engine needs only 20 psig minimum oil pressure at the gauge when operating at normal operating temperature. 30 psig is better.
That is the reason for the low range oil pressure gauge.
The 9N9273A replacment oil pressure gauge is 0-50 psig. The 20 & 30 numbers on the dial are actually larger than the 10 & 40 psig numbers.
The 0 & 50 numbers are smaller then the 10 & 40 numbers.
Understand the reason to go from SAE 30wt to SAE 15-40 wt or SAE 15-40wt to SAE 20-50wt is to compensate for worn crankshaft bearings.
TheOldHokie
04-08-2013 08:11:19
 Re: Need advice re ring/crank bearing replacement in reply to Bulldozer, 04-08-2013 07:19:21
Couple thoughts for you to mull over:
  1. What if any engineering basis is there for that "rule of thumb"?
  2. How does an old flat head B&S lawn mower engine run happily along year after year at 3600 RPM with absolutely zero "oil pressure"?
TOH
Bulldozer
04-09-2013 01:09:43
 Re: Need advice re ring/crank bearing replacement in reply to TheOldHokie, 04-08-2013 08:11:19
and genrators and irrigation pump engines at zero oil pressure with light weight crankshafts and two & four cycle outboard engines and motor cycle engines.
gravity: its the gravity load on the crankshaft.
TheOldHokie
04-09-2013 05:50:33
 Re: Need advice re ring/crank bearing replacement in reply to Bulldozer, 04-09-2013 01:09:43
Bulldozer said: (quoted from post at 04:09:43 04/09/13) and genrators and irrigation pump engines at zero oil pressure with light weight crankshafts and two & four cycle outboard engines and motor cycle engines.
gravity:
What keeps the journal off the bearing surface in a small engine that does not have an oil pump (e.g "zero" engine oil pressure) is the same thing that produces the oil film in an engine with an oil pump. Journal bearings operate on the principle of hydrodynamic lubrication. The oil film that separates the journal surface from the bearing surface is produced by the rotation of the journal dragging the oil inside the bearing clearances around the circumference and constricting it at the narrower load point. That constriction produces a localized pressure gradient inside the bearing that is orders of magnitude greater than oil pump pressure and is opposed to the operating load (and gravity) imposed on the journal. The basic parameters affecting the film thickness are crankshaft load, rotational surface speed of the journal, oil viscosity, and running oil clearance.
You can externally pressurize a normal journal bearing but if the crankshaft is not rotating it remains on the surface of the bearing. It simply sinks to the bottom of the evenly pressurized oil clearance area. When the engine is started and journal rotational speed begins to increase a hydrodynamic pressure gradient is formed at the load point and that pressure gradient acts to push the journal surface away from the bearing surface. The journal/bearing lubrication regime transitions from full boundary mode lubrication (metal to metal) when the rotational speed is zero, to a mixed mode (partial metal to meatl contact) as the speed begins to increase and the film is partially formed, and ideally to full hydrodynamic mode (zero metal to metal contact) when the rotational speed becomes sufficient to produce a gradient greater than the load on the journal. Teh film thickness is determiend by how much the gradient exceeds the load on the journal. Oil pump pressure is not involved beyond maintaining an oil supply adequate to replenish oil lost out the sides of the journal during operation. Small engines traditionally relied on splash lubrication for that oil supply.
TOH
This post was edited by TheOldHokie at 08:17:05 04/09/13 7 times.
Bulldozer
04-09-2013 08:23:26
 Re: Need advice re ring/crank bearing replacement in reply to TheOldHokie, 04-09-2013 05:50:33
Always understood that most of the journal wear occurs at start up rather than at normal operating conditions.
Ok, so why does the flatheat N have the 0-50 psig oil pressure gauge and the OHV NAA have the 0-80 psig oil pressure gauge?
Both engines have equal rated 2000 rpm and nearly equal 6.6/6.7 CR after 85000 serial #.
The oil pump capacity was increased at some point on the N series?
Larger capacity oil pump would increase the back pressure at the journal at equal RPM?
Maybe the larger capcity pump was incorporated to increase the longevity of the engine and not to increase the oil pressure on a new or new rebuilt engine?
So what is the concern about oil back pressure, since the oil pressure is not in the equation for oil film thickness?
In my opinion the N series engine needs to have minimum of 15 psig oil pressure @ 1500 rpm.
Maybe the NAA needs more oil back pressure than the N, since the gauge has a greater range or with a larger capacity pump than the N, the oil pressure is higher.
The tire mfg's are always researching & testing to come up with the ultimate thread pattern to reduce the chance of hydroplaning, which creates a thin film of water between the tire and road in heavy rain conditions. The water film supports the "gravity" weight of the vehicle, which is basically the same physics as the engine journal. Michelin Tire has a great video on U-Tube.
Oil pressure issue seems to be one of the most frequent FAQs on the N forums.
AKA "raven" on the NTC forum
TheOldHokie
04-09-2013 09:56:53
 Re: Need advice re ring/crank bearing replacement in reply to Bulldozer, 04-09-2013 08:23:26
That is normally the case since that is the transition from boundary to hydrostatic regime. Luging an engine alsl contributes to accelerated wear since increased load at lower RPM equates to a reduced oil film thickness and mixed mode lubrication.
WAG - the engineers wanted a higher pumping pressure and increased flow rate to accomodate the greater demands of the OHV design. A flathead doesn't need top end lubrication but an OHV does and it needs it nearly immediately on startup. The oil pressure gauge on my 1963 Triumph equipped with a similar size and vintage Standard engine is 100 PSI and the Leyland specification is a minimum idle hot oil pressure of 30 PSI hot. With an OHV you have to move more oil, move it further, and get it there faster. An OHC is even more demanding in that regard.
It is a easily collected performance metric. The issues I just mentioned are part of that performance but pump oil pressure is also a very good indirect measure of bearing clearances. Bearing clearances ARE a factor in oil film thickness and a low pumping pressure indicates increased clearances and a reduction/loss of the protective oil film.
A fresh engine with good oil clearances will easily make 40 PSI at 1500 RPM. I would say that an engine with 15 PSI @ 1500 RPM is telling you it has wide clearances and/or a worn oil pump and is nearing the end of it's service life. It's those widened clearances that will cause accelerated engine wear - not the low oil pressure.
TOH
L.B,
04-07-2013 13:10:11
Ok, I would suspect if start up and rev-up are the same I would replace the gauge, cheap and will tell you if it may be a weak oil pump. As for blow-by every engine has some and is subjective as to how much you have. Just watch it and you will see some,if it looks like a sketter fogger its not,but not a death sentence either. I had it real bad on a N and I cut it down by 75% with a transmission fluid soak. First get a new gauge it may tell us the whole story as lets not drop the pan and fix whats not broken. Post back what you get. 80 on a dry compression check is NOT bad as 90 to 125 is normal. At this time let do simple. Theres a lot of top notch folks on this site and can save ya time and money. Let see what others have to say.
