TractorLinks.com
Show Parts for Model:
Re: no spark
Plane Bart
04-01-2013 12:54:00
I found on my 9N front mounted distributor the easiest way to remove the distributor is to loosen the 6volt generator and take the belt off use a 1/2" stubby wrench to loosen the two bolts on the distributor remove it from the tractor after you removed the distributor cap and coil. Gap is 0.15 If you have a continuity tester check to make sure you did not ground out the points before you reinstall the distributor.
Firing order is marked on the cap cylinders are 1-2-3-4 #1 is closest to the radiator.
carlntexas
04-01-2013 19:07:27
 Re: no spark in reply to Plane Bart, 04-01-2013 12:54:00
Firing order is 1243
