TractorLinks.com
Show Parts for Model:
Re: At what point do I decide to do a total rebuild?
ASEguy
04-01-2013 05:25:50
I think it depends on what your plans are. If I was going to run it in what it was in, and didn't have lots of time or money I'd do what I did on the 8N given to me again. It sat for 30+ years in a barn. Engine was locked. Patience is the key if you don't want to damage parts. I'd pull the drain plug to see what comes out. If it's clean use fresh oil and replace the filter. Pull the head and put in trans fluid and let soak. Use a 4x4 and a 32 oz. ball pien hammer to tap, not beat the pistons loose. When I freed mine up, I honed the cyl. walls and used oil to aid in compression. Mine doesn't smoke and runs well. I too got lucky which is why I would be patient and not assume the worst. Prime the oil pump through the front plug, replace all hoses and belt. Wiring too. Rebuilt the carb, cleaned out the tank and it works fine. Hope this helps. Gerard
