TractorLinks.com
Show Parts for Model:
Re: 39 ford N won't crank need help
Royse
03-31-2013 17:49:55
On the back of that switch, is there mechanical linkage or a couple of wires?
If it has a couple of wires, they probably go to an added solenoid.
The solenoid would have two large terminals, one from the battery and one
going to the starter. You would jumper those two large terminals to bypass it.
Again, making sure it's in neutral and blocking the clutch down as you are
bypassing any safety mechanisms.
But if that's how it is set up, you have some more variables instead of just
the mechanical linkage and the big switch.
You have the little push button that could be bad, the wiring and the solenoid
itself to test. Not a big deal, we just need to know how its hooked up.
Tgkobal
03-31-2013 17:58:56
 Re: 39 ford N won't crank need help in reply to Royse, 03-31-2013 17:49:55
thank you so much for the information. It does have wires and not the linkage. I will check it out and update you tomorrow evening. thanks to all for the help.
