Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 39 ford N won't crank need help
soundguy
03-31-2013 10:41:44
an 8v alt huh? pos or neg grnd?
I'll leave that lil headache to someone else.
the machine will start and run with no alt or genny.
start switch is a manual job between the thumb button on trans top and back of steering pedistal via linkage.
charge battery.. clean connections.. close switch.. starter should roll.
post back
HCooke
03-31-2013 11:10:52
 Re: 39 ford N won't crank need help in reply to soundguy, 03-31-2013 10:41:44
Or, if it is really a '39 then the start button is on the dash.
Tgkobal
03-31-2013 11:58:04
 Re: 39 ford N won't crank need help in reply to HCooke, 03-31-2013 11:10:52
The start button is on the dash. It is a push button. As for the alternator I will get info off it and update you tomorrow.
Royse
03-31-2013 15:33:44
 Re: 39 ford N won't crank need help in reply to Tgkobal, 03-31-2013 11:58:04
Is the push button on the dash an electrical push button momentary switch?
If so, that may be a game changer. That would probably be wired to a solenoid.
Still would work fine, solenoid still could be jumped with jumper cables etc,
but the wiring will be different.
Tgkobal
03-31-2013 16:23:19
 Re: 39 ford N won't crank need help in reply to Royse, 03-31-2013 15:33:44
It is a push and hold to crank switch. What is the best way to bypass it?
soundguy
03-31-2013 11:20:34
yeah.. if it is an early one.
still mechanical though.. actually easier to work on too.. though not safer.. :)
HCooke
03-31-2013 12:00:26
 Re: 39 ford N won't crank need help in reply to soundguy, 03-31-2013 11:20:34
" though not safer"
Yep. The stroy I heard is that Henry started one in gear and had the the design changed.
soundguy
03-31-2013 13:05:10
 Re: 39 ford N won't crank need help in reply to HCooke, 03-31-2013 12:00:26
i've heard a couple stories.. including some sort of misshap at a factory.
who knows. in any case.. glad he did.
