TractorLinks.com
Show Parts for Model:
Re: 39 ford N won't crank need help
Tgkobal
03-31-2013 09:25:22
It does have the push button. I will jump wires and see if I can get it to crank. Thanks
old
03-31-2013 09:52:37
 Re: 39 ford N won't crank need help in reply to Tgkobal, 03-31-2013 09:25:22
If it has an alternator and is + ground good chance the smoke has escaped from the alternator and will cause many problems like a dead battery. Unless it has an alternator made in England that is. Plus unless custom it would be 12 volts so an 8 volt battery would fry if the charging system works. I would start by pulling the alternator off and have it checked and then find a good 12 volt battery and hook the system up - ground
Tgkobal
03-31-2013 10:07:09
 Re: 39 ford N won't crank need help in reply to old, 03-31-2013 09:52:37
I spoke with the owner and he did have it modified to 8 volts some years ago. I will test the push button start switch and hope thats it. thanks.
