TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Hard Starting
Royse
03-30-2013 17:15:45
That gas has to go somewhere, it can end up in the crankcase diluting your oil.
You may want to check or change it if you haven't already.
With the front mount distributor you take it off the tractor, set the point gap
and timing all on the bench and put it back on. There's nothing you have to
set while running with a timing light as with other ignitions.
The procedure is in the I&T FO-4 manual or can be found in the archives here.
If it has set for a while the valves may be sticky. Just working it may help.
