Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9n Carb
Waterworth Farms
03-30-2013 17:07:27
I'm sorry for not being clear. At one time in the life of this tractor, both ears have been broken off at the flange. The part that mounts to the intake. Someone took the broken pieces and the bolts and used a brazing rod to "weld" everything in place. It obviously worked up until the point that I removed the carb. Now the bolt,(it is the forward bolt, or the bolt on the flange that is most toward the front of the tractor), is broken off again.
03-30-2013 19:02:41
 Re: 9n Carb in reply to Waterworth Farms, 03-30-2013 17:07:27
if i didn't find one.. i'd simply braze or weld it and then true it up with a file and uuse a good gasket.
can make a bit of a backer plate under it to help..add studs tothe plate.. attach the carb tot he plate with silver solder or braze. 3/16 metal would work fine...
03-30-2013 17:36:14
yep, sounds as if you need a new carb. Either a used one bought off ebay ( TSX 33 or TSX 241 both marvel/schebler will work, rebuild it or have someone else rebuild it. Or buy a new reproduction zenith carb ($$$$$$) But just finding the upper half of the carb to fit a 2n8n9n is alittle hard to find someone parting out just the top of the carb.
Bob Harvey
03-30-2013 17:41:55
 Re: 9n Carb in reply to flatlanderfool, 03-30-2013 17:36:14
You forgot that GB in MT, he may pipe in and have what is needed. First you have to check his hat size !!! ;^) HTH
