Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: ford n's are possessed!
GB in MT.
03-23-2013 06:50:18
You ARE still working on the 2N front mount....RIGHT????????
If you are.....It's possible that the plate is moving, and changing the points settings!!????
Advance/retard screw on the side of the distrib, may be loose/and or stripped letting the points plate slide around....????????
Don't take much movement there to change/close up the points setting!!!!
Check it out for stripped threds if the screw is loose!!!!
Gary (Just a thought) :?:
03-23-2013 07:12:33
 Re: ford n's are possessed! in reply to GB in MT., 03-23-2013 06:50:18
correct this is a 1946 2N i drug this one out of a hole where it had sat for 20 years, about 5 years ago and refurbished it to a nice looking working tractor, ive done probably 5 or 6 N series and 3 fergusons and never had this problem i just cant understand this
03-23-2013 08:09:51
 Re: ford n's are possessed! in reply to ericlb, 03-23-2013 07:12:33
Is rubbing block plastic or phenolic (a layered composite material)?
03-23-2013 07:05:27
the screw on the side for the plateis tight i checked that,the snap ring fits tight on the plate, the star washers under the screws on the points are tight,and the stars themselves are in good shape the advance meckenism under the plate is free, and no slop, the eccentric screw for points adjustment is working properly, now when i set thepoints when new they will gap at 0.015, but after i run the engine a minute or 2 they close, and will no longer gap, that is the ecentric screw will move the point base but i cant gap the points, this happened on 3 different sets of points i tried different ones as i thought maybe they got regular china junk in blue streak boxes, so where in the world it this thing getting the slack? nothing makes any sense the shaft with new bushings installed has no slop side to side or up and down, can it be that the store is peddling junk points in the good boxes, and can the rub block really wear that much in that time?
