TractorLinks.com
Order Ford 8N Parts Online
Re: 8n no spark ideas?
waterman74
03-22-2013 20:40:01
Thanks guys. I'll check it tomorrow. Any way to test the condenser?
Dell (WA)
03-22-2013 20:57:12
 Re: 8n no spark ideas? in reply to waterman74, 03-22-2013 20:40:01
waterman........you ask......"any way to test the condenser?"........Well, there are condenser testing meters that are $$$. You don't want to go there. Others can find a capacitance tester function on modern digital multi-meters
There are 3-failure modes for condensers. 1) OPEN...burned points; but still makes sparkies 2) SHORTED...NO sparkies, ...ie... points don't work
3) LEAKY...gradual disappearance of sparkies, usually 1-min time frame, will restart in about 5-mins
Bottom line, replace yer points and condenser as they come in a "kit". Points fer yer 5-nipple sidemount 8N are gapped 0.025". Remember to "polish" the INVISIBLE CORROSION from between the points after installation and adjustment. Me? I clamp a clean $1-bill between the points and pull. Iff'n yer really cheap, tear a strip from HEAVY brown paper grocery sack and use that. .........Dell, yer self-appointed sparkie-meister
JMOR
03-22-2013 20:50:58
You can't "test "one properly without condenser testing equipment, BUT you can at least determine if it is shorted or open with an analog Ohmmeter. Should be infinite Ohms (if Zero it is shorted). Swapping meter leads back & forth on the cap will produce momentarily needle deflection if it has some kind of capacitance (use high Ohms scale).
