TractorLinks.com
Show Parts for Model:
Re: Bruce Tip 53: exhaust leak/pitted block
Hobo,NC
03-22-2013 19:38:13
If it works it works I don't wanna be the test dummy... If it does not work I would track down the dummy that dreamed up the hole drill'n ... I would never add that to my tips that I personally did not test and confirm after quite a few years of hard hard hard use... I can see a man trying to get a years worth of service from a issue like this its not that hard to repeat it as needed.. But when the engine is disassembled WHY rigger nag it :!: and be proud of it...
IMHO I personalty con-dim the hole drilling...
Den N Ms
03-24-2013 10:37:43
 Re: Bruce Tip 53: exhaust leak/pitted block in reply to Hobo,NC, 03-22-2013 19:38:13
Hobo,I'm with you on that one! Also if I had a block out and stripped down and it was eroded around the exhaust ports.It would make a trip to the milling machine and that problem would be gone.NO #53 needed.
