Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Back to the
McNugget
03-21-2013 13:00:06
I removed the timing gear from the crank, had a friend with a 3D printer print a drive adapter for the pump, suspended the pan on long bolts, and installed just the timing cover so I could run the whole system oil circulating system with my cordless drill.
The camshaft has to be clocked in the right position or the oil flows out the grooves in the cam bearings and you will never get pressure. With everything set right you can watch the pressure change with pump speed. The poppet valve open/close can be observed too, and the influence of stretching the spring to increase the pressure is easily demonstrated.
I have videos (.MOV files) if someone wants to host them...
Copyright © 1997-2015 Yesterday's Tractor Co.
