2n pops at high speed
cdv
2n pops at carb at full throttle runs fine at low speed so i just put new 437 plugs,,napa condenser ,points,and rotor new coil,and a new carb and still pops what is there left to do thanks cdv
cdv.........sounds like you need NEW COPPER-CORE sparkie wires. ($15, cheap) Cut to length. You doubt??? Go lookie at sparkies dancing on top of the insulation at nite. .......Dell, yer self-appointed sparkie-meister
if it sounds like it is making popcorn, it's a hair lean.. tug choke a bit.. if it goes away.. enrich the main needle a bit..
