TractorLinks.com
Order Ford 8N Parts Online
Re: Quick 8N Points Question
JMOR
03-21-2013 08:43:22
Must have been modified somewhere along the way, as there was no nylon screw in an original front mount distributor, or side mt either.
PeteMitchell
03-21-2013 09:08:22
 Re: Quick 8N Points Question in reply to JMOR, 03-21-2013 08:43:22
Interesting. On my points, the nylon screw is the one that holds down the breaker points and the copper connector to the screw that contacts with the coil wire.
JMOR
03-21-2013 09:21:05
 Re: Quick 8N Points Question in reply to PeteMitchell, 03-21-2013 09:08:22
Quoting Removed, click Modern View to seeIf I follow your description, then I suspect that paper insulators 1 & 2 are missing & some other arrangement has been made (nylon washer & screw), so the washer should be between points/copper strip & the breaker plate part (approximate location marked with 1 ).......want to insulate points/copper strip from breaker plate part the screw goes into.
PeteMitchell
03-21-2013 10:13:57
 Re: Quick 8N Points Question in reply to JMOR, 03-21-2013 09:21:05
Thanks. That's what I figured.
L.B,
03-31-2013 00:27:32
 Re: Quick 8N Points Question in reply to PeteMitchell, 03-21-2013 10:13:57
your welcome
