Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Bruce Tip 53: exhaust leak/pitted block
Gustafson
03-21-2013 08:32:48
I left the manifold on for about an hour, then removed it and set up my work lights to cure the epoxy. I used a meat thermometer stuck in a head bolt hole to gage the temperature. The block temperature topped out at about 130 degrees after a couple hours under the lights.
kylemorley
03-22-2013 19:20:57
 Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:32:48
Oh, probably worth mentioning that Thermosteel is not epoxy - "high temperature" epoxies usually have a max temp of only 400-500 degrees, which is probably a bit low for this application, compared to Thermosteel's claimed 2400F.
Don't mean to be picky but we don't want anyone going out and buying the wrong stuff.
Actually, I wouldn't be surprised if Thermosteel is just a good grade of refractory cement with maybe a bit of metal dust mixed in as a filler. Refractory cements usually are good up to 2000-2500F
Gustafson
03-21-2013 08:42:29
The hard part was cleaning off the excess epoxy. I had used way too much and that stuff sticks to the steel real well.
I started with a die grinder to remove the Thermosteel that had squished out around the manifold. Then I tried various other methods to flatten the epoxy in the manifold clamping area. In the end, the best method I found was to wrap 80 grit sandpaper around a wood shim and sand the surface flat, by hand. It took about two hours to clean up the block.
POPGUN
03-21-2013 13:59:37
 Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:42:29
SORRY I hope my reply below the first photo didn't mess this whole thing up,dummy me!Sorry Gust.
Bruce (VA)
03-21-2013 13:23:28
WOW!
The first page of "The Illustrated 75 Tips"!
Thanks much. This is worth saving!
Colin King
03-21-2013 11:05:02
What a great walkthrough and photo documentation. Thanks for sharing.
Colin, MN
Copyright © 1997-2015 Yesterday's Tractor Co.
