Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Bruce Tip 53: exhaust leak/pitted block
[Return to Forum]
Gustafson
03-21-2013 08:18:40
63.153.144.213
I used Bruce 53 method to repair my pitted block. First step is to drill 1/8" diameter holes, 1/8" deep in the areas that have eroded.
[Reply]   [No Email]
Royse
03-24-2013 11:57:35
69.36.49.151
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:18:40
Guys, take a look at tip #53. It doesn't mention drilling holes.
  [Reply]  [No Email]
Hobo,NC
03-22-2013 19:38:13
71.30.82.226
Re: Bruce Tip 53: exhaust leak/pitted block in reply to old, 03-21-2013 08:18:40
If it works it works I don't wanna be the test dummy... If it does not work I would track down the dummy that dreamed up the hole drill'n ... I would never add that to my tips that I personally did not test and confirm after quite a few years of hard hard hard use... I can see a man trying to get a years worth of service from a issue like this its not that hard to repeat it as needed.. But when the engine is disassembled WHY rigger nag it :!: and be proud of it...
IMHO I personalty con-dim the hole drilling...
  [Reply]  [No Email]
Den N Ms
03-24-2013 10:37:43
184.41.163.220
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Hobo,NC, 03-22-2013 19:38:13
Hobo,I'm with you on that one! Also if I had a block out and stripped down and it was eroded around the exhaust ports.It would make a trip to the milling machine and that problem would be gone.NO #53 needed.
  [Reply]  [No Email]
Hobo,NC
03-21-2013 18:45:38
71.30.82.226
Re: Bruce Tip 53: exhaust leak/pitted block in reply to soundguy, 03-21-2013 08:18:40
IMHO grip would be the least of my worries...
  [Reply]  [No Email]
Hobo,NC
03-21-2013 17:41:09
75.117.67.126
[quote="Gustafson"](quoted from post at 19:18:40 03/21/13) I used Bruce 53 method to repair my pitted block. First step is to drill 1/8" diameter holes, 1/8" deep in the areas that have eroded.
If I had been were you were it it would have went to a machine shop and milled... I don't understand drilling the block anyone care to splain that...
  [Reply]  [No Email]
Bob Harvey
03-21-2013 18:31:20
209.121.225.156
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Hobo,NC, 03-21-2013 17:41:09
The surround holes are to let the product have a grip/adhere to the block. IMHO
  [Reply]  [No Email]
kylemorley
03-22-2013 06:14:49
96.61.93.225
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Bob Harvey, 03-21-2013 18:31:20
Drilling it like that gives me the creeps. Eventually (in 5, 50 or 500 years) the job will have to be done right, and all those holes will just make it harder.
Besides, I can't imagine they really are going to increase adhesion much over what is already provided by the pitting. It doesn't take much to key two surfaces together when they are bolted together flat like this. Also these fillers are not very strong in sheer so I doubt drilling down a full 1/8th really adds anything to the repair.
I could be wrong, though. It would be interested in trying it both ways on a dozen or so machines and see if there was any significant difference in how long the repair lasted.
Myself, I have a skived, tapered gasket that has been doing the job nicely for 30 years, but I think next time I have to to do the job I'll use whatever the latest and greatest high-temp filler is - but without the holes.
  [Reply]  [No Email]
01BIRDDOG
03-21-2013 16:48:05
50.147.88.242
Very well presented with such good pics. Thank for posting it.
  [Reply]  [No Email]
POPGUN
03-21-2013 13:42:31
64.187.79.169
I love it when a plan comes together. It is nice to see a job well done and you take a lot of pride in your work. To me working on things is a art form and you are a true artist,great job!!!!!!!!!!!! Bruce put this man's work for the world to see.
  [Reply]  [No Email]
Gustafson
03-21-2013 08:22:11
63.153.144.213
Then the thermoSteel is applied using a flat screwdriver blade. I used about half of a 3oz. bottle of ThermoSteel, and I could have used much less.
  [Reply]  [No Email]
Gustafson
03-21-2013 08:24:13
63.153.144.213
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:22:11
A sheet of wax paper is applied over the still-wet ThermoSteel.
  [Reply]  [No Email]
Gustafson
03-21-2013 08:26:59
63.153.144.213
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:24:13
The manifold is installed over the wax paper and tightened down good and tight.
  [Reply]  [No Email]
Gustafson
03-21-2013 08:32:48
63.153.144.213
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:26:59
I left the manifold on for about an hour, then removed it and set up my work lights to cure the epoxy. I used a meat thermometer stuck in a head bolt hole to gage the temperature. The block temperature topped out at about 130 degrees after a couple hours under the lights.
  [Reply]  [No Email]
kylemorley
03-22-2013 19:20:57
96.61.93.225
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:32:48
Oh, probably worth mentioning that Thermosteel is not epoxy - "high temperature" epoxies usually have a max temp of only 400-500 degrees, which is probably a bit low for this application, compared to Thermosteel's claimed 2400F.
Don't mean to be picky but we don't want anyone going out and buying the wrong stuff.
Actually, I wouldn't be surprised if Thermosteel is just a good grade of refractory cement with maybe a bit of metal dust mixed in as a filler. Refractory cements usually are good up to 2000-2500F
  [Reply]  [No Email]
Gustafson
03-21-2013 08:42:29
63.153.144.213
The hard part was cleaning off the excess epoxy. I had used way too much and that stuff sticks to the steel real well.
I started with a die grinder to remove the Thermosteel that had squished out around the manifold. Then I tried various other methods to flatten the epoxy in the manifold clamping area. In the end, the best method I found was to wrap 80 grit sandpaper around a wood shim and sand the surface flat, by hand. It took about two hours to clean up the block.
  [Reply]  [No Email]
POPGUN
03-21-2013 13:59:37
64.187.79.169
Re: Bruce Tip 53: exhaust leak/pitted block in reply to Gustafson, 03-21-2013 08:42:29
SORRY I hope my reply below the first photo didn't mess this whole thing up,dummy me!Sorry Gust.
  [Reply]  [No Email]
Bruce (VA)
03-21-2013 13:23:28
24.125.80.178
WOW!
The first page of "The Illustrated 75 Tips"!
Thanks much. This is worth saving!
  [Reply]  [No Email]
Colin King
03-21-2013 11:05:02
71.49.81.17
What a great walkthrough and photo documentation. Thanks for sharing.
Colin, MN
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
