TractorLinks.com
Order Ford 8N Parts Online
Re: ford 8n
Royse
03-20-2013 19:24:47
Ok, here's how I would check it.
The timing cover is a small round cover held on with one bolt over a hole on
the right rear of the block at the flywheel. Turn the cover to the side and you
can see the timing marks on the flywheel through the hole.
Set the engine with #1 piston (front) 4 degrees before top dead center on compression stroke.
Look to see where the rotor is pointed under the distributor cap.
It should be pointed at the #1 spark plug wire on the cap.
If it is not pointed at #1, we either need to move the plug wires around the cap
so it is, or re-position the distributor or both. That should get you close.
Normally I would check the points opening at this point, but you said you had
installed electronic ignition right? That I'm afraid I can't help with at all.
