xring........look at the right side of the N-Block, you'll find cast indications of where the fuelpump would fit. And NO, the gravity fed N-Carb does NOT need a fuel pump.
Did'ja know early WW2 Jeeps used the N-Engine??? and the driver seat was ontop of the gastank??? Yep, needed a fuel pump and down-draught carburetor. ........historian Dell
(quoted from post at 22:26:40 03/20/13) Industrial engines had fuel pumps & downdraft carbs.
75 Tips
Not all Industrial engines had fuel pumps. The one I have with an Industrial data tag never had a fuel pump! Would depend on what it was used for I believe.
thanks for the info I use to have a jeep cj5 "65 model it had a 4 cyl and I built a plywood body and put 16" tractor and imploment tires on it and man would it dig even the asphault street one time trying to pull a u-haul truck stuck I got to though. pulled a lot of stumps too thanks again
'DEM real WWII "ford" jeeps are now really PRECIOUS.
I see a few during the EISENHOWER WWII re-enactments, here. Minimum investment is $40,000.00
How come everyone is a buddy in the MUSEUM BUSINESS?? Just make a few calls, somewheres!
Our barns are too loaded with BULK. Just a few family pieces left.
John,
