Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: So I used Zane's Hydro adjustment jig today....
ZANE
03-20-2013 07:07:35
I cover the problem with the draft linkage being badly worn in the pin area in my instructions. I hope you read the whole thing before you started the process. That wear pattern on the anchor plate is an indication of a lot of wear from useage.
You can still get the draft linkage to work if you will follow my trick mentioned in the instructions with the flat washer. No need to even remove the lift cover to do it.
Read it again.
Zane
Thanks,John,PA
03-20-2013 16:44:13
 Re: So I used Zane's Hydro adjustment jig today.... in reply to ZANE, 03-20-2013 07:07:35
Your emblem is still doing its DUTY on my service van.
John
