video or pics of 2n distributor tear down
ericlb
going to tear down this 2n distributor and was wanting to watch a video or see some pics of just how it all comes apart so i dont do anything stupid, all i can find is how to install the points which is simple,mainly i want to know how it gets disassembled after the points ect are out i see the snap ring on the breaker plate anybody taken pics or know of a clip i can watch also going to be doing this in the field 20 miles from the house so i need to see if i need anything special i dont already have on the truck
Why are you pulling it down? And doing it in the field where stuff gets dropped & never found again? (BTDT)
Sometimes you gotta do what you gotta do.....but assuming you really do need to pull it down, I'd just go get it off the tractor & pull it down on the bench.
75 Tips
may do that but the field 20 miles away is where the tractor broke down, im tearing it down to replace the bushings ive done plenty of distributors in cars and trucks but not one of these
If you bend the tower that holds the front bushing, you will be buying a new plate.
That's yet another reason to do the job on a work bench.
Unscrew the timing screw. Remove the C clip. Take out the plate. Check the advance weights. (replace/repair as needed) Pres out the front & rear bushings. Press in the new ones & ream to fit.
75 Tips
thanks,i stopped at the tractor and got the distributor and will do this on the bench here,not out in the field where the tractor is sitting
