Did the 2N or even the 8N"s ever have a "Ground Speed" selection on the PTO shaft?
Probably not? but then againI have never seen such an option to be sure. Reason is that I thought of what if the PTO of one machine could be used as the input of a reversed/turned upside down other rear end of a 2N machine[with required mounts/u-joint/housing closure, etc as required to make a small porter type unit?
tks
tks
