| Ford 9N, 2N & 8N Discussion Forum |
Topic: 2n distributor problems
[Return to Forum]
| Author |
[Modern View]
| ericlb
03-17-2013 18:54:42
70.41.154.247
working on a "46 2n, the problem is points slipping and i cant figure out why,ive replaced the points 4 times today and each time the problem is the same, it starts and runs about 1 minute, then quits, fire to the coil, but no fire to the plugs, when i pull the distributor the points have closed up, both screws are tight, and are not stripped, im ready to crush this thing, what is going on and what do i do about it?? |
[Reply] [No Email] | |
| Royse
03-18-2013 15:11:45
69.36.49.151
Re: 2n distributor problems in reply to ericlb, 03-17-2013 18:54:42
| They press out and back in, mine came out fairly easily.
You will want to support the distributor well, especially when doing
the front one so the metal holding the bushings do not get bent.
They're available lots of places including YTMag. About 1/3 way down the page |
| 36 coupe
03-18-2013 04:46:36
69.49.142.155
| Rubbing block on new points plastic or very rusty lobe on cam.Last 9N dist. I checked could not get 015 gap.New points adjusted ok.Points get very hot when running and melt plastic.Dist bushings could be badly worn. |
| ericlb
03-18-2013 04:54:01
12.189.32.37
Re: 2n distributor problems in reply to 36 coupe, 03-18-2013 04:46:36
| sting here wondering about the bushings too ,nothing else makes sence, i didnt feel any slop,but it doesnt take much to eat 0.015, saw a small amount of brass particles, but not many, how hard are those to change? |
| soundguy
03-18-2013 05:35:47
108.112.36.226
Re: 2n distributor problems in reply to ericlb, 03-18-2013 04:54:01
| as 36 said.. look at the rubbing block.. is it worn down any? |
| ericlb
03-18-2013 14:55:48
12.189.32.54
Re: 2n distributor problems in reply to soundguy, 03-18-2013 05:35:47
| the block isnt worn, looks new as when i put them in yesterday, also what about centrifugal advance? would that do it? how much problem will i encounter taking the distributor apart? ive done old chevys and fords but not one of these, looks a little different |
| soundguy
03-19-2013 06:09:53
184.240.126.46
Re: 2n distributor problems in reply to ericlb, 03-18-2013 14:55:48
| | there's no magic in it if that's what your asking. the advance should give you rotational play.. and that's about it.. should not effect points closing up. bad bushing will give you eratic gap though... |
| ericlb
03-17-2013 20:53:33
12.189.32.54
| the screws are the original ones as far as i l know,no slop that i can find all seems ok, the original problem was a bad ballast resistor, i ordered a new one, but the tractor was hot wired and operated by somebody, i figured the points got burned up so i replaced them, even though they didnt look burned also replaced the condenser, i have never seen one do this without a reason, the screws are still tight when i pull the distributor , but the points are closed |
| BillM (OH)
03-17-2013 21:53:40
173.81.81.180
Re: 2n distributor problems in reply to ericlb, 03-17-2013 20:53:33
| star washers under the screws??? |
| ericlb
03-18-2013 04:18:03
12.189.32.54
Re: 2n distributor problems in reply to BillM (OH), 03-17-2013 21:53:40
| yes the star washers are there,this thing is driving me nuts, ive got to get it going, but ive never seen one do this, when i remove the dist. the screws are still tight, so i cant figure what is changing with just a minute or 2 of run time |
| TOM N MS
03-17-2013 19:02:41
172.6.29.244
| Do you have the correct screws, correct length in the points? Too long won"t work.. |
| Royse
03-17-2013 19:00:25
69.36.49.151
| No definitive answer here, but is there slop in the distributor shaft?
It might be beating your points up and/or pushing them out?
Others will have more ideas. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
