Just got my 9N back from being overhauled and the mechanic had it almost a year outside his shop and all the ignition wiring to the 12 V key switch is rusted out. The engine was running while I was bushhogging when it just stopped. I moved the battery terminals and it started again. After replacing the battery wires, a wire from the solenoid side where the battery is hooked up came off and I think it was attached to the key switch. All the terminals on the key switch are coroded and I will have to replace it and them. Anyway the tractor won"t start but there is power going to solenoid but nothing to the switch.
Is there a diagram that demonstrates where the wires go on the switch? I guess I can get a standard key switch from Auto Zone that has an ACC on it.
Anyone have any ideas? Thanks.:dunno:
