TractorLinks.com
Order Ford 9N Parts Online
Re: 9N no spark
tom bleeker
03-17-2013 09:00:49
i had the same problem as bruce said pig tail coil grounded.if the copper band is broke use copper srape from old points and punch holes.not my idea my brother inlaws he a milewright. i watched a guy on you tube install distributor with every thing coil and cap installed then put it on ( do not do it) install like bruce said make sure you fell it drop into slot or you will by a knew distributor . i told my self after i took old one apart i needed one any way . the inside was very loose main armiture where arms slide out . it was fait or my own screw up
