TractorLinks.com
Show Parts for Model:
Re: 12 Volt Conversion - Fried two Alternators
HeyObie
03-16-2013 08:51:51
We have Napa around here and can get one for $49. It is a three wire. Can you share how to wire it up? Or is it too hard to explain.
This post was edited by HeyObie at 08:58:50 03/16/13.
notjustair
03-16-2013 12:28:28
 Re: 12 Volt Conversion - Fried two Alternators in reply to HeyObie, 03-16-2013 08:51:51
Google it - there are good diagrams out there. I only use the three wire jobs. They are simple to do.
old
03-16-2013 08:59:41
I never do the 1 wires any more due to odd problem caused by them. Like battery drain and high RPMs needed to exciter them etc. The 3 wire ones are simple to hook up and if as I said you have an O'Reilly's close to you they come with a lift time warranty so if it does go bad you can take it back and get a new one for free. The 3 wire has as it says 3 wires. The big charge wire which you hook like the 1 wire and then a plug with a #1 and #2 wire. The #2 goes to the charge stud on the alternator and the #1 with a diode in line radio shack #276-1661 goes to the ignition side of the coil or the ignition switch the coil side and your done
