Curtsat15
Hey guys, kind of a weird question considering how long I've been following this forum. For my 46 2N, I'm just wondering how big I can go with implements. Specifically, discers (1 or 2 gang), cultivators and plows (Pretty sure 2 bottom on this one), and snowblower (I have a 5 foot blade now that works great, but have a 6 foot single auger blower in the works). I know a 5 or 6 foot bush hog is about the limit for these guys. And just out of sheer curiosity, what about generators? Any ideas?
If you are asking about A.C. power generator / emergency back-up, forget it. A Wal Mart or TSC unit is WAAY more fuel efficient and can be had for just about whatever you want to pay. HTH
I have used a 2 gang 5 foot disk behind an 8N. A 2 bottom 14 is tops for one in my area. Cultivator who dose that any more?? I have one and it has sat in the same place now for I bet 10 years
I should probably add that the soil here is fairly heavy, although not like the red clay you southerners have. What we call loon $h1t. We're at the bottom of an ancient lake bed and it is extremely fertile dense soil. Right in the middle of the bald a$$ prairie. Very much like northern ND and NW MN.
I'm not farming with mine, just maintaining property, driveways, gardening
and putting in food plots, but here's my experience.
I pull a 2/14 plow in MI red clay. Works very well when the moisture is right.
A single 16 inch I've heard works just as well if not better.
I have a 6 foot two gang disk that doesn't seem to bother them at all, unless
I put too much weight on it, then they get light loafers in front when I lift it.
5 ft rotary mower works well. I wouldn't want a 6 ft in high grass/weeds.
I don't have a cultivator, yet, but I would think a two row 3 pt for a garden
or smaller field work would be a breeze. Used as a cultivator.
Without live PTO and a cab, I haven't bothered to try a snowblower.
No idea on the generator. PTO generators are high around here.
I could buy 3 new 5000W portables for the price of a used PTO setup.
I have the same set-up that Royse does with the addition of a 2 row cultivator and a 6 foot back blade. All will work great on the 2N. I use my 8N as my only farm tractor on a 40 acre farm.
PTO generators are expensive to purchase and expensive to operate (a 4 cyl gas Ford tractor engine uses a lot more fuel than a 1 cylinder modern Honda engine). But they are probably better made than the new generators and they give you the benefit of 1 less engine to maintain - a major plus in my book.
Erskine and Arps made pull-type snowblowers for the N. There are currently a few listed in MN Craigslists for about $450. Do some searching. The modern style snowblower might work with patience, but the lack of live PTO would present a serious challenge if you're moving deep snow.
Colin, MN
Thanks guys. I'm preparing about 2 acres for garden and berry patches. I have access to a couple implements and I'm just looking for advice.
I have a 2-14 plow, 6' tandum disk, sprayer, auger, sub soiler (1 shank) 5 foot finish mower, 5' brush cutter, 2 row corn planter, 6' rear blade, cultivator set up for 2 row and a cultivator set up for field work. they all work pretty good.
Yea if it's the right size it would run a generator. Northern tool sells a 7200 watt one for right at 1K that only needs 14 HP but the 13,000 watt requires 24 hp.
Yea they can run a blower too but it wouldn't be fun. Love my blower setup, 112 HP tractor with cab on an 8' blower, CAB, live PTO, CAB, live hyd, CAB.....did I say CAB????? 16" of fresh snow really makes it bark. I don't think my N would do that much snow very well.
Rick
The reason I ask about a generator, is there's a 40kw coming up at a farm auction at the end of next month. Wondering if my little N could handle that. If not maybe my Power Major?
Northern Tool, 27,500 Watt, 48 hp required.
Power Major is rated at 48 HP PTO. Don't know if that would do it.
Rick
I have a nice cultivator with new shovels if you think you might be interested, or anyone else for that matter. My e-mail is open.
I found that 2-14" was too much plow trying to open sod in our stony, rooty, clay loam soil. N with good engine and wheel weights really struggled and I kinda felt I was abusing it.
I found a 1-16" and that was a great combination.
It plowed deep and good and straight. Turned the soil over nicely. Tractor liked it much better as did I.
It wasn't till I went to a 33 hp Ford that I could adequately pull those 2-14s
I used a 7' disc afterwards. That is 4 gangs with 5 blades each. I could add a couple hundred # of rocks to the disc and still lift it as needed without the tractor's front wheels coming up.
