TractorLinks.com
Show Parts for Model:
Re: Aftermarket radiator is a bit off.
Ken N Tx
03-11-2013 03:28:05
Ron-MO, not sure when you purchased your radiator, but there where issues prior to 2011.
I purchased one that they said came from a different manufacturer. The only problem that I had was the pre-installed mounting bolts where spaced a 1/8th of an inch off..All I had to do was open up the mounting holes to make it fit.
As far as the shroud fit, I do not have one so "no comment".
Ron-MO
03-11-2013 07:25:28
 Re: Aftermarket radiator is a bit off. in reply to Ken N Tx, 03-11-2013 03:28:05
The (new) radiator I purchased was in 2006, however the issues I had was not with the mounting bolts, it was similar to the issue with the top filler neck as mentioned in this post, but in addition I had obvious issues with the holes to mount the shroud. The first (used) aftermarket radiator had issues with not only the filler neck, but also the outlet, and it has been some time, and I cannot recall details on that issue. Sure seems to be a lot of junk, and some of the junk is being sold by supposed "restoration" suppliers (which was the case on the new radiator I purchased). I wish I had taken the time to persue getting my money back (with shipping cost both ways) from this supplier rather than try to modify the radiator to make it fit, as in my opinion paying over $200 for a "restoration" radiator from a seller who specializes in N parts should not mean you have to either make it fit, or live with an ill fitting radiator.
