Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Aftermarket radiator is a bit off.
Ron-MO
03-10-2013 15:54:50
Been there, and done that on two different radiators - one of which I purchased from a supposedly reputable seller of "just 8N" parts. I ended up repairing my old radiator and putting it back on. I now have two radiators (one nearly new) sitting in boxes in my shop somewhere collecting dust. If I recall correctly the last one I purchased new I could not fit the shroud correctly and ended up slipping with a drill (accidentally) and going into the core with the drill - making my day even better. I was really disappointed as I also purchased some other parts from them including some of the tie rod boots which lasted about a month before cracking and breaking. I read constantly on this site that the company I purchased from is a reputable company to deal with (not this site), but in my opinion, if parts do not fit correctly (as was the case with the radiator), or will not last more than a month I have to disagree. My advice, if your radiator can have a new core put in, that would be what I would do, as paying a couple hundred for something like what you have pictured is not worth the hassle of trying to make it fit.
Ken N Tx
03-11-2013 03:28:05
 Re: Aftermarket radiator is a bit off. in reply to Ron-MO, 03-10-2013 15:54:50
Ron-MO, not sure when you purchased your radiator, but there where issues prior to 2011.
I purchased one that they said came from a different manufacturer. The only problem that I had was the pre-installed mounting bolts where spaced a 1/8th of an inch off..All I had to do was open up the mounting holes to make it fit.
As far as the shroud fit, I do not have one so "no comment".
Ron-MO
03-11-2013 07:25:28
 Re: Aftermarket radiator is a bit off. in reply to Ken N Tx, 03-11-2013 03:28:05
The (new) radiator I purchased was in 2006, however the issues I had was not with the mounting bolts, it was similar to the issue with the top filler neck as mentioned in this post, but in addition I had obvious issues with the holes to mount the shroud. The first (used) aftermarket radiator had issues with not only the filler neck, but also the outlet, and it has been some time, and I cannot recall details on that issue. Sure seems to be a lot of junk, and some of the junk is being sold by supposed "restoration" suppliers (which was the case on the new radiator I purchased). I wish I had taken the time to persue getting my money back (with shipping cost both ways) from this supplier rather than try to modify the radiator to make it fit, as in my opinion paying over $200 for a "restoration" radiator from a seller who specializes in N parts should not mean you have to either make it fit, or live with an ill fitting radiator.
Bob Purinton
03-10-2013 17:24:53
Been there; done that. I was straightening fins on my old radiator and turned it into a garden sprinkler. Water coming out everywhere. The shroud off the original one wouldn't fit the new one. That doesn't seem to be a problem as it's never gotten hot to the point of boiling over. I still got my old one but I gotta make do with what I got being out of work at the moment. The new one works fine; it's just not shaped like the original. BTW- There seems to be more parts that don't fit correctly than parts that do. I'd like to have the money back that I've blown on almost-but-not-quite fits parts from China or Mexico. Aside from not fitting you also got the quality issues you mention.
Ron-MO
03-10-2013 20:24:18
 Re: Aftermarket radiator is a bit off. in reply to Bob Purinton, 03-10-2013 17:24:53
Probably the part that bothered me the most was that since I had problems with an aftermarket radiator I had purchased used, I called this vendor (who comes recommended by many on this site), and specifically asked if this radiator would fit properly, and explained to him the issue with the other one. He assured me I would have no problems. The only reason I did not call return the radiator and demand my purchase cost and shipping back was due to the fact I damaged it trying to make it fit (I was sure this was the only way to get my tractor going in time for hay season). I knew there was no way they would even talk to me after I drilled for the shroud, and punched a hole in the core. I admit the majority of the parts I purchased from them are fine, but radiator and tie rod boots certainly were not among them. I noticed on their site now it lists the radiator dimensions as "Its dimensions, size, construction and appearance is close to the original". Kinda like "almost right". Reminds me of a used fender I purchased for a pickup a couple years ago.......they said it was a good straight fender, ready to paint, but when I received it they had wrapped it in saran type wrap, and slapped a shipping label on it. It arrived with 3 creases in the fender which was worse than the one I had, so I ended up using my original, but I ended up getting my credit card charges reversed, and told the seller he could pick up the worthless fender. end of rant, but I am still sore over that radiator. :-)
This post was edited by Ron-MO at 20:26:24 03/10/13.
