TractorLinks.com
Show Parts for Model:
Re: Aftermarket radiator is a bit off.
L. B,
03-10-2013 12:41:44
You need to also adjust the upper radiator hose so the rad sits up straight and make sure your green fiber shim goes all the way around the rad neck.Most important that in all your adjustments the fan clears the radiator 360 degrees. Make sure your hood is on correcly and it not part of the alinement problem.
Bob Purinton
03-10-2013 15:14:37
 Re: Aftermarket radiator is a bit off. in reply to L. B,, 03-10-2013 12:41:44
Yes the hood is on correctly. The radiator is as it bolted on. I can move it back but I didn"t want to torque on it too hard. I know the mount on the tractor is slotted but I think it is back as far as it goes. I"ll look at that again.
It looks like I got almost an inch between the fan and radiator. I have an old mudflap I can use for rubber to shim up the radiator a little. Might have an old inner tube from my motorcycle, too.
