Thanks for all the responses below, I probably wouldn"t venture into setting timing and adjusting points without the help of this forum, the manuals don"t always explain it simply enough for me to follow. So thanks. Anyway, next question, FO-4 says "Move the stationary contact point as necessary to obtain air gap 0.0024-0.0026 inch", Operator manual says to insert distibuter adjusting wrench No. 12150-A in adjustment openings and turn proper direction to .024-.026. Everywhere else I"ve seen confirms.025 instead of .0025 so I"ll assume the F0-4 is a misprint. But, what exactly am I adjusting to achieve the proper gap and what do I use? Also, FO-4 shows direction of spin CW for the sidemount in Fig. FO86, but the firing order on mine seemed to indicate CCW. Which is correct? BTW, '50 8n side-mount for those who didn't see the earlier post.
