TractorLinks.com
Show Parts for Model:
Re: choke
Bill Rowles
03-08-2013 10:24:00
Eric, your throttle/governor problem is likely caused by linkage out of adjustment or maybe the wrong compensating spring is installed. There are two different governors used on the NAA; original is no longer available and the replacement unit requires a different compensating spring. Someone may have replaced the governor but mistakenly used the original spring. I suggest you get the IT Shop Service FO-19 manual which explains this and also the procedure for linkage adjustment. My NAA tractor had governor problems and after adjusting the linkage it is much better. The engine should not require much "choke" to start and mine needs partial choke setting for the first couple minutes of operation in real cold weather starts.
