TractorLinks.com
Order Ford 9N Parts Online
Re: 9n generator
noble527
03-08-2013 07:47:24
welp, last night went I got home, I applied voltage to the genny, and she spun, so im assuming that means it will generate some sort of voltage. Ordered a new starter cable, 0 gauge, and going to re wire. Hopefully after this is all said and done she will charge! Im thinking that my amp meter is probably ok, and no need to replace. Any testing ideas on the cut out, to check and see if its working properly? Thanks again for all the info!
Mad Farmer
03-12-2013 19:40:48
 Re: 9n generator in reply to noble527, 03-08-2013 07:47:24
You can jumper the two wires on the cutout when it is running. It it charges jumpered you have a bad cutout , or connection at cutout
JMOR
03-08-2013 10:38:59
Quoting Removed, click Modern View to seeThere are 2 terminals on the cut out, one to battery & one to generator & they are specific & not reversible. Contacts inside the cut out close to connect battery to generator or open to disconnect battery from generator. From a start, as generator voltage increased with increasing RPM, the generator voltage will reach about 7.0 to 8.5 volts and within that range the contacts will close, connecting generator to battery. If you place an analog voltmeters leads on those 2 cut out terminals, they should show voltage up until the contacts close, at which point that voltage should drop to zero.
Upon engine shut down, as generator slows toward a stop, the generator voltage drops and at some point, the contacts should open to disconnect the battery from the generator, at which time the meter should read a value equal to battery voltage (stopped engine).
