Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Had to pull the 2N out of hibernation
Larry O
03-07-2013 17:56:35
Yes that one scare was enough and we thought we had it planed so good Notch cut good and site cleared but it still Settled back closing the gap and all most catching the saw Larry
BillM (OH)
03-08-2013 19:38:01
 Re: Had to pull the 2N out of hibernation in reply to Larry O, 03-07-2013 17:56:35
Looks like that tree has quite a bit more weight on the house side - it wants to fall on the house, no matter what you do, unless you are pulling on it pretty strongly away from the house.
Colin King
03-08-2013 16:34:06
I had an "oh sh!t" moment a couple of years ago. I was clearing a 60 foot red pine from a neighbor's yard. The tree was tall and straight, and I figured I could hinge it to make it swing away from the house. Well, what I didn't calculate was the temperature effect on the wood. On that particular day, the air temp was about -10F, and frozen wood snaps. My hinge snapped with a thickness of a couple of inches. The tree turned just enough that the top of the tree landed about 5' from the picture window. I was lucky!
Colin, MN
D beatty
03-07-2013 18:48:13
You need to get the plastic wedges that they use . They help the bar from getting pinched and help force tree to go the direction you want.
teddy52food
03-07-2013 18:29:24
I sure don't like the looks of that notch. Way too wide from top to bottom & not deep enough.
soundguy
03-07-2013 18:01:55
i hate working on the ones under tension that start to twist and moan as you are cutting thru them.. UGH.. bad sound / feeling...
Larry O
03-07-2013 18:32:53
 Re: Had to pull the 2N out of hibernation in reply to soundguy, 03-07-2013 18:01:55
Yes but it was worse when the tension loosened and it settled back toward the house luckily the one in front didnít once we got the 2N on the chain now there is one more jest like it at the other side of the front. The roots are going back under the house and about this age they start splitting and I donít need one splitting and taking out something like a corner of the house
soundguy
03-08-2013 15:03:39
 Re: Had to pull the 2N out of hibernation in reply to Larry O, 03-07-2013 18:32:53
nothing like sseing wood moving towards the house!
Copyright © 1997-2015 Yesterday's Tractor Co.
