TractorLinks.com
Order Ford 9N Parts Online
Re: 9n generator
JMOR
03-07-2013 10:43:56
Quoting Removed, click Modern View to seeIF your battery is installed with + (large post to tractor chassis ground, then connect your charger reverse to what you described. i.e., charger + to either of barrel posts AND charger negative (-) to single post on rear end plate of generator (Arm terminal). I have made dozens of diagrams, but if you found one for 9N with cut out and generator, then you probably have the correct diagram. One other thing, you would be better off using jumper cables & connecting gen to battery than trying to use charger...charger my not yield enough output, may no provide any output if a newer automatic type, etc.
