Adam Brandt
New User
I have a 52 8N which I have been having an issue
with. Basically after running for longer than 10
minutes, when I change gears and use the clutch it
will act like it is going to die, and runs rough
for a few seconds and if I ease into gear slowly
it runs fine, but if I release the clutch fast it
dies. I replaced spark plugs, checked for spark
which is good, fuel flow seems to be fine,
replaced the coil - no difference. I am not sure
what else to check. The cap rotor and points are
all clean and look good. I am thinking of
replacing the spark plug wires, but they look good
so I dont think that is the issue. Any ideas?
