TractorLinks.com
Show Parts for Model:
Re: Removing bearing cone
William Fissell
03-07-2013 05:51:12
I don't have the (easy) ability to lay down a bead. I bought a stick welder but am waiting for the electrician to hook up a 50 amp service.
soundguy
03-07-2013 07:23:42
 Re: Removing bearing cone in reply to William Fissell, 03-07-2013 05:51:12
got a dryer or stove? :)
the amps you need to lay a bead that will shrink a race are low.. you don't want lots of penetration on this. I use 6013 and low amps.. just enough to burn the rod..
William Fissell
03-07-2013 07:38:21
 Re: Removing bearing cone in reply to soundguy, 03-07-2013 07:23:42
@Sounder: yes, but... the boss may not enjoy the smoke plume from the welder in the kitchen..... I guess I can run a LOOONG dryer cord. :)
soundguy
03-07-2013 08:00:27
 Re: Removing bearing cone in reply to William Fissell, 03-07-2013 07:38:21
for a temp 3 wire hookup and low amps.. a piece of 10-2 will make a welder run off a dryer plug ;)
I bought my welder a week before I had a welder plug put in my shop.
I neede dit to repair my 15' batwing mower.. the wing FELL OFF!
I parked it in the driveway near the garage door, and rub-goldberg'ed a 15$ roll of 10-2 to the dryer outlet and my welder using a lil hardware to make sure the wires didn't unplug / safety. etc. was welding for 15 minutes. just had to put a stop plate on to hold a hinge pin in, and re-weld the forward wing hinge.
worked fine.. :)
wife did wonder why there was a cable runing from behind the dryer out the door into the garage and out the garage door :)
William Fissell
03-07-2013 09:38:45
 Re: Removing bearing cone in reply to soundguy, 03-07-2013 08:00:27
:) love it. I actually do have a roll of 10-2 lying around, i think....
TheOldHokie
03-07-2013 17:24:55
 Re: Removing bearing cone in reply to William Fissell, 03-07-2013 09:38:45
I used some #10 SJ cord to make a HD extension cord for my welder years ago. Put a dryer plug on one end and a dryer receptacle on the other. The welder is now in the shop on it's own circuit with 50 ft of more of welding lead on it but I still use it from time to time if I want to get the box outside the overhead doors. Heck - it might even pass NEC muster......
TOH
soundguy
03-07-2013 11:32:47
do shut the breaker off while making this miracle of NEC code breaking happen.. ;)
and be safe!!!!
I'm not responsible if you do it wrong and something bad happens. :)
William Fissell
03-07-2013 17:26:04
 Re: Removing bearing cone in reply to soundguy, 03-07-2013 11:32:47
Well, I waited until my wife was out of the house and I just threw a 220 plug on the Lincoln buzz box and plugged it into the 220 that was closest to the driveway. The wires stretched out into the driveway. barely.
Anyway, I laid down a grotesque chicken-poop bead and it is cooling now. I never used an arc welder before (yes, I used a helmet and goggles and gloves and and and...)
We'll see if I have to do it again.
soundguy
03-07-2013 17:35:37
 Re: Removing bearing cone in reply to William Fissell, 03-07-2013 17:26:04
if it made any penetration at all.. you are probably fine. on races.. I use low amps and a lo pen reod..
William Fissell
03-10-2013 07:30:35
 Re: Removing bearing cone in reply to soundguy, 03-07-2013 17:35:37
Second time round, total success. Thanks for the help.
soundguy
03-10-2013 20:09:38
 Re: Removing bearing cone in reply to William Fissell, 03-10-2013 07:30:35
cool deal!
