Much obliged to those who helped me get the charging worked out, now I need a little help reigning it in.
Battery charged showing 6.4 volts. Ammeter shows +10 amps at 1/4 throttle and +20 at 3/4 throttle. Gen output is 8 volts at 1/4 throttle and over 10 volts at 3/4 throttle. Battery shows 8 plus volts at high throttle.
Read soundguys post from long ago and disconnect field at Gen, killed charge. Disconnected field at vr, same result. Bad vr or bad wiring? Don't wanna spend the $ on a new vreg or the time on new harness in the dark.
Disconnecting either field also helped it run better, odd. Its having trouble at high rpm, can't get to full throttle. Can't tell if rich or lean and adjustment helps slightly. Carb just cleaned, spotless.
