Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: OT Ford F100 think I found the problem
Ken(Ark)
03-04-2013 17:48:36
From what I can remember of the post on the Ford truck site , The original Autolite chokes are the way to go because they do not work as an on/off set up but as the air being pulled through the tubes starts to warm up it gradually moves the choke . So the choke decreases as the motor warms up and not just a close or open situation .
I think they are a combination of electrical and a bi metal coil spring ?
I could be wrong but I was interested in the posts since I have always had cold natured used Fords that I had to keep pumping the gas to keep it running .
Britcheflee
03-04-2013 23:09:43
 Re: OT Ford F100 think I found the problem in reply to Ken(Ark), 03-04-2013 17:48:36
this is the part I need:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=CRB24982_0063886573
The bi-metallic spring is on the other side of the carb.
Bill Crowell
03-05-2013 12:16:56
 Re: OT Ford F100 think I found the problem in reply to Britcheflee, 03-04-2013 23:09:43
If your truck is subject to smog inspection, a manual choke on a vehicle originally equipped with an automatic choke will fail the visual inspection.
Copyright © 1997-2015 Yesterday's Tractor Co.
