Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Priming oil pump for first start on new rebuild
Bob Harvey
03-04-2013 17:08:24
I suspect you are 'pushing the envelope' on the assembly lube. Do as mentioned, add some HEAVY oil - 90 wt gear oil is fine, it will dilute with the small amount required. Put the oil in, button up FAST and crank over with the plugs out and ignition off. You should get a reading on the pressure guage. If you do, put the plugs in and crank it up. Good luck !
03-04-2013 17:24:00
 Re: Priming oil pump for first start on new rebuild in reply to Bob Harvey, 03-04-2013 17:08:24
Thank you Hcooke and bob for your advice I feel relieved now that"s great! And easy enough!!! Many sleepless nights thinking of a dry startup!!!!!
