TractorLinks.com
Order Ford 9N Parts Online
Re: 9n won't move in any gear but pto works.
soundguy
03-04-2013 11:25:29
yep.. tranny coupler shaft.. pinion splines.. ring gear rivits.. or axle.. those would be the things I'd check..
LDhaas
03-04-2013 16:39:44
 Re: 9n won't move in any gear but pto works. in reply to soundguy, 03-04-2013 11:25:29
I pulled the insp. plate and ran the tractor in gear, drive shaft seemed to turn fine. I tried it in first and second gear.Rear axle did not turn. I noted that the left wheel was extremely difficult to turn while the right axle turned very freely,when I turned them by hand. I'm guessing maybe a broken axle. In any case looks like i got my work cut out. Any advice would be appreciated.
soundguy
03-05-2013 06:03:08
 Re: 9n won't move in any gear but pto works. in reply to LDhaas, 03-04-2013 16:39:44
with machine off, and trans in gear, and left tire setting on ground, if you can turn the right tire freely.. then yep.. axle..
LDhaas
03-04-2013 12:33:15
Thanks guys , I'll check those things .
