Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No governor control
03-02-2013 20:30:39
My first thought was that the gear is loose on the shaft. Had one like that and acted the same.
03-03-2013 04:13:31
 Re: No governor control in reply to notjustair, 03-02-2013 20:30:39
The linkage is hooked up correctly. The throttle lever shaft is hooked to the governor lever, and the other rod goes from the governor lever, to the carb. According to the manual, I'm supposed to pull the throttle lever to wide open (with rod to carb disconnected) then holding the carb throttle plate wide open, the snap on connector from the governor rod, should line up with the ball on the carb linkage, and clip right on.
There was some concern as to the governor assembly slipping on the crankshaft, (as there are no teeth inside the tube) but when we loosened the balancer pulley, it was on very tight.
Could this be an issue where it is slipping on the crank? If so would adding shims behind or in front of the governor work? Thickness of shims?
