TractorLinks.com
Show Parts for Model:
Re: Throttle butterfly plate
soundguy
03-02-2013 15:09:44
worn? installed wrong?
Fins/413
03-02-2013 15:32:20
 Re: Throttle butterfly plate in reply to soundguy, 03-02-2013 15:09:44
Installed wrong I believe.
GB in MT.
03-03-2013 05:45:10
 Re: Throttle butterfly plate in reply to Fins/413, 03-02-2013 15:32:20
Fins;
I just saw this post, and sent you an email. Call the telephone#, that is on the email, and I will walk you through, on the correct way to install the throttle plate, and set up your carb for proper operation!!!!
A posted pic. of the plate area on your carb, would help!!!!!!!!!!
Gary (GB in MT) :wink:
Fins/413
03-03-2013 09:19:08
 Re: Throttle butterfly plate in reply to GB in MT., 03-03-2013 05:45:10
Here is aphoto of the throttle plate in idle postion. Not great but you get the idea. Also its a model TSX 241B
GB in MT.
03-03-2013 09:55:57
 Re: Throttle butterfly plate in reply to Fins/413, 03-03-2013 09:19:08
Fins;
Looks to me like the plate is orientated correctly, in that pic.!!!, BUT something is holding that plate in about the 1/4 to 1/2 throttle possision. Bent throttle rod??? OR the idle stop screw is too long and set at that idle possision!!!!
Like I said.....ifd you will call me at the # I gave you....then I can walk you through what to look for to get that throttle working right.
It may even be that throttle plate is on the rod, on the wrong side....(plate should be down into the cut-out area on the rod.....NOT on the rounded side of the rod!!!!!?????????
Call me....it won't take long, and I am now in the house for a coffee!!!!
Gary :)
Fins/413
03-03-2013 09:59:27
 Re: Throttle butterfly plate in reply to GB in MT., 03-03-2013 09:55:57
I loosened the screws and it moved a bit and closed right up, like I thought it should be from my experience with other carbs
GB in MT.
03-03-2013 10:09:27
 Re: Throttle butterfly plate in reply to Fins/413, 03-03-2013 09:59:27
If that was what was holding it.....then the holes for the plate screws are worn/egged out and you need a new throttle plate, and rod!!!!
Time for a complete carb kit, and cleaning!!!
Gary :lol:
