| Author |
[Modern View]
| Ed S. (IL)
02-25-2013 19:37:50
204.118.86.228
Went out to start the 8N tonight to position it ready to plow the predicted 6-8" of snow coming, and she was flat as a pancake. I wasn't paying attention when I pulled the float charger off, but I suspect I must have hooked it up backwards after the last time I ran the tractor. I wondered why it took so long to register a full charge (weeks).
The battery was showing -0.4volts... Don't know if I can bring it back or not, but I put the float charger back on the right way this time and will check it in the morning to see if the battery is taking a charge. I'm still 6volt positive ground...
I'm over 50 now. Does this count as a Senior Moment?
:P
es |
| tracman
02-27-2013 10:04:26
142.52.81.12
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Ed S. (IL), 02-25-2013 19:37:50
| ED, there is one more thing you can try. With the 10 amp charger, connect a 6v bulb(sealed beam headlight will work) in series with the battery. That will limit your current yet still pass current thru your battery. |
| Ed S. (IL)
02-26-2013 18:51:40
204.118.86.228
| Oh you are a cruel man, Gary!
:P
es |
| Ed S. (IL)
02-26-2013 16:02:16
204.118.86.228
| Just came in from evening chores, and the battery is holding steady at +0.01 volts.
I suspect it's a goner.
I did try hooking up the 10 amp charger, but it throws the internal breaker after about 20 seconds until it cools and resets, after which the cycle repeats.
Looks like I'll be stopping by NAPA soon!
es |
| GB in MT.
02-26-2013 16:34:37
216.47.61.196
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Ed S. (IL), 02-26-2013 16:02:16
| Quoting Removed, click Modern View to see
ED;
Sounds to me like yer "N" battery, has been taking lessons from yer Van....(You know?????)
Bet you thought I had forgotten about that!!!!
Sorry, could not resist!!!!!
Gary :) |
| R Geiger
02-26-2013 15:27:06
50.39.135.182
Re: Oops! Hooked up float charger backwards to 6V battery in reply to 1951 8N, 02-25-2013 19:37:50
Found some online and ordered two thanks! |
| Ed S. (IL)
02-26-2013 14:08:45
204.118.86.228
Menards carries a couple that are auto-sensing.
TSC also has them.
es |
| R Geiger
02-26-2013 13:52:23
50.39.135.182
Re: Oops! Hooked up float charger backwards to 6V battery in reply to dan shu, 02-25-2013 19:37:50
| Quoting Removed, click Modern View to see |
| JMOR
02-26-2013 13:45:11
72.181.173.171
| Dead battery may not be related to reversed float charger, at all. Many (most?) will do nothing if connected in reverse, no help, no harm. |
| tracman
02-26-2013 13:02:47
142.52.81.12
| Ed, the float charger my be going flat as well. The dead battery may too much of a load. You may want to try a higher current (10 Amps) type charger for few minutes to get some volage back on the your plates. Just remeber safety first with eye protection and no sparking at the battery because of the hydrgen gas given off during charging. At my age I have senior hours. |
| Ed S. (IL)
02-26-2013 07:01:26
204.118.86.228
| I might go swap chargers then, although my normal charger doesn't have the ability to set the charge rate - I was kind of afraid of over charging and blowing up the battery...
es |
| GB in MT.
02-26-2013 07:12:54
216.14.246.182
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Ed S. (IL), 02-26-2013 07:01:26
Don't think ya have to worry about blowing up the battery, if the batt. caps have vents, and your charger is not any more than 10 amps!!
If you are worried, just charge with the reg. charger, until it shows 3/4 charge,....then shift back to the trickle charger, to top off the charge.
Then watch yer amp guage, on the "N" to make sure the VR is shutting down at full charge. (Check the voltage at the batt.....key off!!)
Gary :) |
| Bob Purinton
02-26-2013 05:55:17
184.9.182.71
| They say that the mind is the first thing to go... It's the second thing that scares me...whatever that is. :) |
| teddy52food
02-26-2013 07:32:54
184.94.175.179
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Bob Purinton, 02-26-2013 05:55:17
| Mind is the 2nd to go & I forgot what the 1st is. |
| Ed S. (IL)
02-26-2013 05:40:25
204.118.86.228
| Hey, I resemble that remark! (ouch!) I did get asked the other day if I was eligible for a senior discount... The (obviously older) man ahead of me said he was thankful they didn't ask him!
Just came in from morning chores and the battery now shows +0.46 volts (on the float charger). Will keep an eye on it - maybe it will come back.
es |
| GB in MT.
02-26-2013 06:08:20
216.14.246.182
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Ed S. (IL), 02-26-2013 05:40:25
Ed;
Not too sure about this, BUT, I think you may be better off, using a reg. battery charger, with 2amp. charge. Slow charge at 2Amps, would bring the batt, charge faster and keep the plates warmer....JMHO.
Even if it does charge up to full cap, being drawn down so low, may hinder the battery's 'cranking' Amps!!????
BTW...the old Exide battery that you saw on Hermie when you were here, is going on 7yrs in age, and STILL is perkin' like a NEW batt.
Who would'a thunk it????? :lol: :?:
Gary :shock: |
| GB in MT.
02-26-2013 03:22:53
216.14.246.182
ED;
NOT, a senior moment!!!! BUT, .....now I understand the statement on yer T-shirt!!!!! :lol: :lol:
Gary :wink: |
| old
02-25-2013 21:06:02
209.86.226.56
| Only way you might and it is a slim chance to save that battery is to discharge it all the way and then some then slow charge it, but even then not a good chance. As for you age my son has marked the battery chargers so he can remember that red is + and black is - and he is in his 20s |
| Jimmyjack
02-25-2013 20:26:00
216.105.208.69
| Most float chargers just maintain charge or charge a very little, you might have to put a real charger on it to bring it back. |
| TOM N MS
02-25-2013 19:58:05
98.95.137.193
| Over 50 senior moment--Yes and it gets worse |
| Bob Harvey
02-25-2013 19:47:22
209.121.225.180
| Nope, no senior moment points. You are only a senior when the cashier at the supermarket says "thank-you sir". (there may be other markers) ;^) |
| JoeN'Mo
02-26-2013 13:06:51
72.161.89.16
Re: Oops! Hooked up float charger backwards to 6V battery in reply to Bob Harvey, 02-25-2013 19:47:22
| The thing that bothers me is the guys in the Viagra commercials are younger than I am !!! Over The Hill Joe |
| Royse
02-25-2013 19:45:24
69.36.49.151
| It just might!
Ask them for a senior discount if you have to buy a new battery! :) |
